Stoner VS Rossi, the never ending debate
Re: Stoner VS Rossi, the never ending debate
Postby Oscar on Wed Apr 25, 2012 12:06 am
JanBros wrote:so yes, the total force that goes through the CoG to the contact patch is exactly the same, but the size of the forces that determine it change ! the centrigugal needs to be bigger . this is correct in my example (just as I said what happens when Stoner brings the combined CoG lower) : he needs to go faster through the corner or he can't keep the bike at the same angle.
Aha! - I think we are talking the same thing, just I was looking at the (bike + rider) as a single entity i.e. the effective CoG to be reacted through the contact patch of the entire assembly, you are talking about the CoG of the bike and adding the CoG of the rider as a modifier [this gets really difficult to express in words] - so absolutey, with Stoner's lower body position, he has to go faster on the same arc to hold the same lean angle on the bike.
The actual height of Stoner's body, though, isn't the critical thing, it's the sideways displacement: if you established the actual CoG of the bike with his body hanging off and drew a line from the contact patch through that position and extended it, he could be anywhere along that line - but he'd need arms and legs metres long to be able to hang far enough off the side to be on that line and further above the ground. As a very crude analogy: in a plane executing a perfectly balanced turn, no matter how steep the angle of bank, neither a full champagne flute nor a beer stein will spill a drop.
It's all fairly academic (and certainly non-controversial, disobeying the basic premise of this thread..) because the whole dynamic of cornering the things they way these guys do is never going to be steady-state for more than a few moments - though Lorenzo probably gets closer to that than anybody. They are all dancing with multiple force effects affecting what is going on, and Stoner is evidently doing a very good job at the way he balances those out at every moment (as are they all; arguably Stoner gets it a poofteenth better enough of the time to make a difference).
Cappra wrote:When I say that Casey is 'thinking' his way through the corner I'm saying he in unconsciously competently receiving mental and physical input/data, processing that data into unconsciously competent physical skills. And I think the difference is measured in poofteenths and it is the combination of mental and physical skill advantage.
In an earlier interview with Stoner (I can't remember which one) he commented that he always does a few laps quite slowly to assess the track, looking at minute changes in surface etc. for old tracks, looking for the fastest line at a micro-level for new tracks, getting a picture of each corner in his head. He's obviously very good at this - witness Aragon '10, when Stoner was the only top rider who did not ride the circuit before the race weekend started and he was up to speed from FP1.
Postby Cappra on Wed Apr 25, 2012 12:51 am
TwoStroke Institute wrote:The obligation to get on the throttle is nothing to do with coming hard off a corner, it is that when your on the throttle(or brake) you have control. The earlier you are on the throttle the earlier your in control.
And again, do you think Stoner or Rossi are not applying this theory/understanding/technique? I don't think Code's theory of throttle application or Rolando's theory explains why Stoner is faster and, even more specifically, why Stoner can get more speed out of the unpredictable front end grip of the Duke.
TwoStroke Institute wrote: The bit in between brake and throttle is where you have no control.
That is not quite true; the rider still has input through balancing the bike with body positioning - but it is true that braking and acceleration are the dominant forces. And it is very pertinent to this discussion to understand this balancing of rider inputs, and how it is arrived at, to understand the differences in performance between Stoner and Rossi.
Code's theory, style and teaching is a variation of an old racing adage; you either brake flat out or you accelerate flat out - and you minimise everything in between ;) . It is that "minimise everything in between" that we are talking about here. It appears that during the 'tip in' stage and the 'centre' part of the corner Stoner has an advantage over Rossi (and others, Hayden, Capparossi etc etc.). This advantage might be a general advantage or it might be a specific to the Ducati advantage. I think it is a general advantage. I think it is the way Stoner adjust to a host of subtle and constantly varying inputs that is the difference.
Cappra
Postby Cappra on Wed Apr 25, 2012 12:59 am
Rusty Bucket USA wrote:
Except that, at the speeds we're talking about, they're not really "balanced". There's considerable slip/drift/slide in nearly every corner, so all the body positioning (and power sliding) is essentially "wedging" the bike against the "balance" lean angle to coax it into going faster. That doesn't take away from your point, either, but I think it's an important detail in realizing why they do what they do.
An excellent point well made I think - the art of controlling a bike when it is nearly out of control :P - racing :D .
Cappra
Postby sir_nj on Wed Apr 25, 2012 2:23 am
All seem to be pointing to the same little spot in time. I seem to remember quite a few of Casey's front end crashes happend when he was out in front and when asked what happened he said he had actually backed off slightly. Presumably the bit between brake and throttle got slightly longer, meaning for all of the above reasons Casey was no longer able to weight the front and he ends up with another front end lose for NOT going like an idiot. Yeah, I can't imagine why the fun/thrill of that happening would get tiresome :)
sir_nj
Postby TwoStroke Institute on Wed Apr 25, 2012 11:45 am
Maybe it's time to open your own riding school, let me know when you get 49 world/national champions through and I'll book myself in ;) ;)
http://www.superbikeschool.com/news/pre ... is_man.php
Postby Cappra on Wed Apr 25, 2012 3:02 pm
And neither Stoner or Rossi were one of them, and they are only the two greatest riders ever to throw a leg over a bike - maybe it's time for Code to go back to school :P .
Not that this disqualifies anything I said; essentially I was summarizing and agreeing with code.
Cappra wrote:Code's theory, style and teaching is a variation of an old racing adage; you either brake flat out or you accelerate flat out - and you minimise everything in between ;) . It is that "minimise everything in between" that we are talking about here.
Cappra
Postby sir_nj on Thu Apr 26, 2012 8:38 pm
interesting to see Dean Adams come out and basically say Rossi doesn't know sh@t if he thinks Stoner should be thanking Ducati
http://superbikeplanet.com/2012/Apr/120426l.htm
sir_nj
Postby Oscar on Thu Apr 26, 2012 11:27 pm
sir_nj wrote:interesting to see Dean Adams come out and basically say Rossi doesn't know sh@t if he thinks Stoner should be thanking Ducati
Oookayyy - an Adams piece that doesn't have a snide dig at Stoner? What have Soup done with the real Dean Adams? This can only be attributed to post-traumatic shock following wins last year in every US motoGp race by, er, that Aussie bloke...
Postby lebowski on Thu Apr 26, 2012 11:46 pm
Yep - and I actually enjoyed his little piece on Nori's kids terrorising pit lane at WSBK events. Hell, I'm starting to like the guy... :shock:
lebowski
Postby Rusty Bucket USA on Wed May 02, 2012 7:57 am
I realize many have given up on this thread, but for posterity, I'm bringing back the "riding style" aspect of the discussion:
(link to slightly larger original)
(Big credit to RedJet for the screen-captures. Thank you!)
Postby eddahenry on Mon May 07, 2012 9:10 am
Ok since his last tweet Stoner is excluded from this debate due to cheating
He is a RACEANATOR a Racing unit, part man-part machine. Underneath it's a hyperalloy twin spar chassis, microprocessor controlled GPS ECU, very tough. But outside it's living human tissue. Flesh, skin, hair, blood, grown for the cyborgs.
After all the years of the Duck and the 990 honda sending him sky high , and all the years on Dirt Track
here is his broken bones list taken from his twitter
"have only broken my left.(Collar bone)..twice. Other than that only my scaphoid once, 3 bones in 23 years of riding.
CHEATER
eddahenry
Postby CLX on Mon May 07, 2012 2:48 pm
While other guys break 3 bones a year doing everything but riding a bike!
That's me in the picture.
CLX
Postby Cappra on Tue May 15, 2012 12:08 am
This should kick along any debate ;) .
"Is it time to rethink Valentino Rossi's place in MotoGP history? Dennis Noyes consults the numbers…"
http://moto-racing.speedtv.com/article/ ... t-goats/P1
Will someone do the stats using wins and podiums etc for works or factory bikes only. That would change the stats and the historical perspective in Casey favour :twisted: .
Cappra
Postby Grahluk on Tue May 15, 2012 1:12 am
Cappra wrote:This should kick along any debate ;) .
Yes, let's please go through another round of cherry picked stats to support our preconceived bias'.
Grahluk
Postby Oscar on Tue May 15, 2012 1:28 am
Cappra wrote:Will someone do the stats using wins and podiums etc for works or factory bikes only. That would change the stats and the historical perspective in Casey favour :twisted: .
Cappra - for the specific case of Rossi vs Stoner, that means the 800's era (excluding the current season, obviously!) and you'll find everything at:
http://motomatters.com/forum/viewtopic.php?f=2&t=1242&start=150
Page 7 has the completed table for the 800's era. There's some interesting stuff re attempts to 'normalise' the data for various situations in the preceding pages, the later ones tend to drift away from the stats. per se.
Postby Cappra on Tue May 15, 2012 1:32 am
And you think the claims of Rossi being the GOAT weren't backed by cherry picked stats? A casual glance at these stats would say that the claim is very dubious. I just asked for a new "the historical perspective in Casey favour". A different perspective giving new insight, better judgement and a greater appreciation of all racing and all racers ;) 8-) .
Cappra
Postby Cappra on Tue May 15, 2012 1:39 am
Thanks Oscar, an interesting read.
Cappra
Postby Grahluk on Tue May 15, 2012 4:49 am
No, I think the whole goat thing is a ridiculous bit of fanboy slobber be it yellow or dripping from down under but go ahead, have fun, & don't forget to wipe when you're done.
Grahluk
Postby Cappra on Tue May 15, 2012 8:27 am
Grahluk wrote:
No, I think the whole goat thing is a ridiculous bit of fanboy slobber ......
Read my posts and you'll see that exactly my position ;) .
"I just asked for a new "the historical perspective in Casey favour". A different perspective giving new insight, better judgement and a greater appreciation of all racing and all racers ;) 8-) ."
Cappra
Postby MiniNinjaMk5 on Tue May 15, 2012 8:39 pm
CLX wrote:While other guys break 3 bones a year doing everything but riding a bike!
Although Haga went more than a decade into a career without breaking a bone, despite some horrific looking crashes. I know he has broken one now, but when he was younger the guy had rubber bones.
MiniNinjaMk5
Postby Kropotkin on Wed May 16, 2012 6:50 pm
A stat posted by Dr Martin Raines ahead of Le Mans 2012:
In the last 26 races, which include his final six riding the Ducati, Stoner has taken 15 victories; a win rate over this period of 58%.
Whatever you think of him, that's pretty remarkable. I'm guessing you'd have to go back to 2003 or 2004 to get a similar stat for Rossi?
Postby Squidpuppet on Wed May 16, 2012 8:32 pm
Kropotkin wrote:A stat posted by Dr Martin Raines ahead of Le Mans 2012:
This made me curious, so I looked it up.
From the first race of 2001, all the way to PI in 2005, Rossi won 51 of 79 races for a rate of 64.5%.
If we include the final two races of 2005, which Rossi didnt win, he goes 51 from 81 for 62.9%.
Within those years there are numerous blocks of condensed victories tied together that exceed the percentages I listed above.
One example is during 2001-2002 he went 21 for 28 for a rate of 75%.
He had a 14 for 26 run in 2008-2009
Postby Kropotkin on Wed May 16, 2012 8:44 pm
Squidpuppet wrote:This made me curious, so I looked it up.
I was hoping someone would look that up :D Those are pretty amazing stats, for sure. Can Stoner match them? You'd have to say it's tough.
Postby Squidpuppet on Wed May 16, 2012 8:49 pm
Kropotkin wrote:I was hoping someone would look that up :D Those are pretty amazing stats, for sure. Can Stoner match them? You'd have to say it's tough.
Stoner + Honda = doable. IF he stays in the game long enough.
Postby CLX on Wed May 16, 2012 10:25 pm
I'd like to know about their % of laps lead. Stoner's numbers must be over the roof, Rossi's not so much because of how he had a habbit of poor starts and only bothering to lead the last few laps. But they should still make for some good numbers.
CLX
Users browsing this forum: No registered users and 2 guests
