Zaphod wrote:Question for Krop.
Is there any info you can give in regards to where the problems with Spies and the team stem from ? I too would like to see him perform to the level his talent would have us to believe is possible. It seem to the naked eye though, that all is far from well in that side of the garage, excluding what he pulled off at Le Mans, he seems to be down in the mouth a bit...especially with his comment after Estoril that "the championship is over"
Admitedly, that comment may mean that he feels he can no longer run a chance of being World Champ, although it could also be that he means he doesn't feel like he will even finish in a good championship position.
There is a lot of conjecture in regards to the team, for instance the cracked frame, not putting in the effort.
What do you see from where you are ?
Thanks.
I think it's a question of confidence and luck. When you have a bunch of luck run against you, then your confidence takes a knock, and especially after what happened in Qatar, that's just what he doesn't need. One good race could turn things around. I still think he can ride, but he and his team just need a weekend where everything runs smoothly.
